While driving I turn on the A/C engine lost power, shut off and cranks but does not start
167,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
SILENT001
Hi, i was driving my vehicle listed above and when i turned the A/C on it lost power and then turned off. i tried to start it again and it just cranks but no start.
Aug 3, 2021 at 6:19 AM
Good afternoon,
When you crank it over, does the tachometer show RPM while cranking? Trying to see if the crank sensor is working.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Can you hear the fuel run for 2 seconds with the key on?
I would also check the compression to be sure the timing did not change.
Aug 3, 2021 at 7:44 AM
