Car will not start
150,000 MILES • 2WD • MANUAL
JEWELZ8701
After replacing fuel pump car still wont start. It cranks like normal but wont catch.
Jan 23, 2019 at 3:05 PM
Good morning,
Why did you replace the fuel pump? Did you test for power?
You need 3 things to run, spark, fuel pressure and compression.
I would start with a fuel pressure test. Can you hear the pump run?
The next thing is the spark. remove a spark plug wire and test for spark when cranking.
Lastly, you need to do a compression test. This will tell if the valve timing.
Jan 23, 2019 at 10:24 PM
  • 55,732 POSTS
What ever happens to this? Did you get it fixed or?
Jul 29, 2019 at 3:41 AM
