Car will not start
JEWELZ8701
  • 2000 FORD ESCORT
  • MANUAL
  • 150,000 MILES
After replacing fuel pump car still wont start. It cranks like normal but wont catch.
Wednesday, January 23rd, 2019 AT 11:05 PM
  • 52,797 POSTS
Good morning,
Why did you replace the fuel pump? Did you test for power?
You need 3 things to run, spark, fuel pressure and compression.
I would start with a fuel pressure test. Can you hear the pump run?
The next thing is the spark. remove a spark plug wire and test for spark when cranking.
Lastly, you need to do a compression test. This will tell if the valve timing.
Thursday, January 24th, 2019 AT 6:24 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,643 POSTS
What ever happens to this? Did you get it fixed or?
Monday, July 29th, 2019 AT 10:41 AM
