Transmission will not shift out of first gear
200,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
WES FITCHHORN
I change the water pump in my car put it all back together timed it. now it won't shift from 1st gear.
Feb 13, 2020 at 9:37 AM
Good evening,
Is the check engine light on? If it is, do you know the code?
I attached a flow chart and possible issues.
The throttle position sensor is critical in shifting. If the ECM does not see the signal, it will not shift.
Check the voltage with a scan tool to see if there is a signal being sent to the ECM.
Feb 13, 2020 at 10:59 AM
