Car will not rev up when gas is pushed
2002 JAGUAR X-TYPE
260,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
JOSHHH
I just bought the car, I was able to drive it home and everything. I knew there was problems that was going to need fixed after I took the intake off to check spark plugs. it won’t rev up when I press the gas.. I have a code reader, I replaces the MAP, MAF, ignition coils, spark plugs, and have a fuel pressure sensor on the way everything it said was wrong but it still won’t rev. What could the issue be?
Oct 10, 2019 at 11:45 AM
  • 110,244 POSTS
Welcome to 2CarPros.
If there is no throttle response, chances are it is related to one of the throttle position sensors. There are two on the engine and one on the accelerator pedal itself.
What I need you to do is check for diagnostic trouble codes related to these sensors. One will most likely be at fault.
Here is a quick video showing how to retrieve codes:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but often times a parts store will lend / rent one to you. This is a test that really needs done otherwise it becomes a guessing game.
If I had to guess (and I don't like doing that) I would say the sensor on the accelerator pedal itself is bad. If one of the other 2 was an issue, I feel you would get some degree of throttle response.
Let me know what you find or if you have other questions. Also, if you need more information, I need to know if this vehicle was made for the US market.
Oct 11, 2019 at 12:04 PM
JOSHHH
See I have already replaced a TPS and it still doesn’t show that I’m pressing in the gas.
Oct 14, 2019 at 6:48 AM
  • 110,244 POSTS
Which sensor was replaced? Was it the one on the pedal or on the throttle body?
Oct 14, 2019 at 10:42 AM
JOSHHH
It was the throttle body sensor.
Oct 14, 2019 at 2:03 PM
  • 110,244 POSTS
There is also a sensor on the gas pedal. Here are the directions for testing it. Let me know if you have the tools needed.
__________________________________
2002 Jaguar X-Type (X400) V6-3.0L
Test B: Accelerator Pedal Demand Sensor
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection P Code Charts P1215 Test B: Accelerator Pedal Demand Sensor
TEST B: ACCELERATOR PEDAL DEMAND SENSOR
B : DTC P1122, P1123, P1215, P1216, P1344
B1 : CHECK THE ACCELERATOR PEDAL DEMAND SENSOR OUTPUT
1. Turn the ignition switch to the RUN position.
2. Measure the voltage between electrical connector PA1-6 and ground with the accelerator pedal released and with the accelerator pedal at full throttle.
3. Measure the voltage between electrical connector PA1-3 and ground with the accelerator pedal released and with the accelerator pedal at full throttle.
Does the voltage vary between 0.3 volts and 5 volts?
Goto B4
Goto B2
B2 : CARRY OUT AN ACCELERATOR PEDAL POSITION SENSOR COMPONENT CHECK
1. Remove the accelerator pedal.
2. Measure the resistance between pin 1 and pin 6 of the accelerator pedal.
3. Measure the resistance between pin 2 and pin 3 of the accelerator pedal.
Is the resistance between pin 1 and pin 6 between 546 and 1134 ohms, and between pin 2 and pin 3 between 975 and 2025 ohms?
Goto B3
INSTALL a new accelerator pedal. For additional information, refer to . CLEAR the DTC. TEST the system for normal operation.
B3 : CHECK THE ACCELERATOR PEDAL DEMAND SENSOR CIRCUIT FOR A SHORT TO GROUND
1. Disconnect the PCM electrical connector EN16.
2. Measure the resistance between electrical connector PA1-6 and ground.
3. Measure the resistance between electrical connector PA1-3 and ground.
Is the resistance greater than 10,000 ohms?
Goto B4
REPAIR the accelerator pedal demand sensor circuit from the PCM to the accelerator pedal. CLEAR the DTC. TEST the system for normal operation.
B4 : CHECK THE ACCELERATOR PEDAL DEMAND SENSOR CIRCUIT FOR OPEN CIRCUIT
1. Disconnect the PCM electrical connector EN16 and the accelerator pedal electrical connector PA1.
2. Measure the resistance between EN16-103 and PA1-6.
3. Measure the resistance between EN16-102 and PA1-3.
Is the resistance less than 5 ohms?
DIAGNOSE the electronic engine control system.
I attached two pics so you can see which sensor I am referring to. Let me know if this helps or if you have other questions.
Oct 15, 2019 at 10:04 AM
