Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Engine
Symptoms
Low Power
Engine will not rev pass 2500 rpm's
1995 TOYOTA COROLLA
254 MILES • 1.8L • 4 CYL • 2WD • MANUAL
REINALDO ORTEGA
MEMBER
I need help. I cannot think about anything else. Car starts and will run but cannot pass 2500 rpm's and i do not have check engine light on.
Jan 12, 2018 at 11:16 AM
Experienced Mechanic
Good morning.
You need to have someone check the timing. It may be off one tooth resulting in the power loss.
Start there and let us know. A shop can do this test by doing a compression test.
Jan 12, 2018 at 7:44 PM
REINALDO ORTEGA
MEMBER
That got done. some cold start will be perfect but then the problem will comes again.
Jan 13, 2018 at 6:52 AM
What was the compression??
Also, it could be a clogged catalytic converter. that can be checked with a back pressure check to confirm.
Jan 13, 2018 at 6:56 AM
REINALDO ORTEGA
MEMBER
The car is in limp mode
Jan 28, 2018 at 11:54 AM
Ok. can you tell me the codes??
Jan 28, 2018 at 6:35 PM
REINALDO ORTEGA
MEMBER
Its no code
Jan 29, 2018 at 12:43 AM
ok, did you do a compression test??? Thats where we need to start to see if the motor is in time.
Jan 29, 2018 at 12:46 AM
REINALDO ORTEGA
MEMBER
Piston1 175 piston2 170 piston3 165 piston4 175
Jan 29, 2018 at 1:16 AM
ok, good
I am wondering if the cat converter is clogged.
Try unbolting the front pipe to the manifold and see if it runs any better
Jan 29, 2018 at 2:04 AM
REINALDO ORTEGA
MEMBER
I took cat converter off...if it does have a bad fuel pump can it still run?
Jan 29, 2018 at 2:07 AM
yes, if the pressure is below specs. can you check the fuel pressure??
Jan 29, 2018 at 2:08 AM
REINALDO ORTEGA
MEMBER
U think it could be the igniter
Jan 29, 2018 at 9:55 AM
I doubt it.
what about the fuel pressure???
Jan 29, 2018 at 9:57 AM
REINALDO ORTEGA
MEMBER
I cant check fuel pressure until i get the tool for it...but i did get code 14
Jan 29, 2018 at 10:49 AM
that is for the ignition control circuit. this could be related to the igniter but you need a scope to verify the signal.
do you have access to a scope>>
Jan 29, 2018 at 11:07 AM
REINALDO ORTEGA
MEMBER
My cylinder head doesn't have the port for the egr system do u know how to trick the ecu for that?
Feb 15, 2018 at 4:50 AM
there is no trick to fool the ecu.
check the connections at the igniter to be clean tight and no damage to the pins.
check the distributor cap and rotor as well for any damage or wear.
Feb 15, 2018 at 5:06 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
