When transmission is shifted into drive the car hesitates then jumps forward and shuts off
202,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
KBEE
  • 9 POSTS
When you select the drive or reverse the car does not move then suddenly it will jump forward and cut out. Also if it do start and driving the two front wheels locks off in traffic which is very dangerous.
Thanks,
Kbee
Feb 27, 2020 at 8:51 AM
Good afternoon,
This sounds like the filter is clogged in the transmission.
When was the last time you change the fluid?
Feb 27, 2020 at 8:55 AM
KBEE
  • 9 POSTS
Hi Roy Thanks, your reply was very informative. I appreciate your help very much.
kbee
Feb 27, 2020 at 9:32 AM
You are welcome.
Always glad to help.
Keep me updated.
Feb 27, 2020 at 9:34 AM
