It is grinding from the rear ?
55,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JREGZ
I got in my car, started it up, released the parking brake, and put the car into reverse. It is grinding from the rear I need new brake can you help me please?
Mar 27, 2020 at 5:46 AM
Here are some guides that will help with this:
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
https://www.youtube.com/watch?v=GwU7nfBaRr0
https://www.youtube.com/watch?v=j8YwfSKEzZo&t=29s
Please let us know what questions you have but below is the process from the manual on how to replace the rear brakes. Thanks
Apr 24, 2021 at 3:44 AM
BWHITEHAIR
Ive changed brakes before, but not on this car. I see they come with a hardware kit, but seems old hardware is hard to get out. Any Suggestions?
May 11, 2021 at 6:24 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Should not be any different with others.
What hardware kit are you refering to?
1. Remove Upper caliper guide pin bolt (1). To do so, hold the guide pin (3) stationary while turning bolt.
2. Rotate caliper downward (5), exposing brake pads (2 and 3).
Use care not to overextend brake hose when doing this or damage may occur.
3. Remove inboard (2) and outboard (3) brake pads from caliper adapter (4).
Note : In some cases, it may be necessary to retract caliper piston in its bore a small amount in order to provide sufficient clearance between shoes and rotor to easily remove caliper from knuckle. This can usually be accomplished before guide pin bolts are removed by
grasping rear of caliper and pulling outward working with guide pins, thus retracting piston. Never push on piston directly as it may get damaged.
BWHITEHAIR
Ok thank you much. Will try it out. The hardware kit are the anti squeel shims. Autozone.com is saying these are required
KHLOW2008
  • 41,812 POSTS
Yes, shims do rust out and it is necessary to have them to eliminate squealing and groaning noises when brakes are applied.
Hope everything works out great.
Have a nice day.
OLANDRIA
I have had a problem with replacing the rear brakes, Can someone please help me?
Jun 28, 2021 at 12:41 PM (Merged)
Here is a guide that will help with step by step instructions on how to do this:
Also, here is a guide on how to retract the rear pistons:
Below is the info from the manual that will help with this. Please run through this material and let us know if you have other questions. Thanks
CARGIRL77
I think I need to replace the rear brakes. Thank you in advance. Mindy
Here are a few guides that will help with step by step instructions. Please review this and the material below.
Below you will find the process from the manual that will give additional details. Please run through all this material and let us know if you have any questions. Thanks
Jun 28, 2021 at 12:42 PM (Merged)
AMBROJSHIA
At first I was driving and i hear a little noise from the rear but not the brakes are grinding can you help me please? Tia
Sounds like you do need rear brakes. here is a guide that will help with step by step instructions:
Below is the process from the manual that will help with this. Please let us know if you have any questions. Thanks
MIRANDANUNLEY
. Last week (first morning that it was below freezing this year) when I went out to drive the car and I heard the rear brake grinding.
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. Here is a tutorial showing how to replace rear rear brake pads and rotors:
Here is a YouTube video from our site showing how to retract the rear caliper piston when replacing rear brake pads:
https://youtu.be/j8YwfSKEzZo
I've attached picture steps below on how to change the rear brake pads and rotors on your car. Hope this helps and thanks for using 2CarPros.
