Car will not move
162,000 MILES • AUTOMATIC
KAYCEE9027
My car cranks up just fine I can put it in any gear. But when I press the gas the car will not move at all. When looking at the tires I can see it trying it’s hardest to move but nothing. Any help
Dec 18, 2018 at 12:18 AM
Good morning,
Are you sure the brakes are not locked up? check your handbrake and make sure it is fully released. Does it move in reverse?
Beyond that, have you checked the fluid? When was the last time the fluid and filter was changed in the transmission?
Dec 18, 2018 at 12:40 AM
KAYCEE9027
I have been told the transmission is completely done that is why it will not move.
Dec 18, 2018 at 1:53 AM
Okay, got the video. thanks.
The only thing you can try is changing the oil/filter in the transmission. beyond that it will be an internal failure requiring a rebuilt or used unit to replace.
Dec 18, 2018 at 2:29 AM
