Car will not go after radiator hose broke
123,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
BRITTANY BREWER
My radiator hose busted. I replaced it now the car will not drive in reverse or first and it shakes.
Oct 15, 2019 at 12:21 PM
SCGRANTURISMO
  • 4,897 POSTS
Did your vehicle overheat when it the radiator hose broke? A radiator hose being busted would not keep a vehicle from going or going in reverse. If a vehicle is overheated usually what happens is the aluminum head, which has a lower melting point than the iron block warps and this cylinder head warpage causes the head gasket[s] to fail. A good a quick way to tell if this has happened is to do a compression test on your vehicle's engine. Here is a link below describing how to do this:
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Oct 15, 2019 at 10:00 PM
