My vehicle just stopped going?
200 MILES • 3.4L • 6 CYL • 4WD • MANUAL
GLENDAHAWKINS
I shifted and it shut off and won't drive.
Nov 17, 2022 at 12:54 AM
  • 110,248 POSTS
You indicated it shut off and won't drive. Is the engine not running and won't restart? Or does it run but when placed in gear it won't move?
If the engine will not start, try this and let me know what you find.
First, see if the engine will start with starting fluid. If it does and then fails, we know it is a fuel related issue. If there is no change, it sounds like an ignition related issue. At this point, I need you to check if there is spark to the plugs.
Here is a link that explains how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Nov 17, 2022 at 10:43 AM
