No crank no start
2004 PONTIAC BONNEVILLE
279,000 MILES • V6 • 2WD • AUTOMATIC
RACER3681
I had to change the ignition even the the passkey and it still will not start or even turn over. I tried to do the relearn and still nothing. Anything that I can do?
Aug 4, 2018 at 11:51 AM
Good afternoon.
Is the theft light or security light out since you did the relearn?
That may not have been the issue since there is more to the system.
It could be the ignition switch, neutral safety switch, starter itself or wiring. Has anything been checked?
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
Aug 5, 2018 at 7:39 AM
