Car will not crank
57,000 MILES • 4.6L • V6 • 2WD • MANUAL
ROY C
Was driving car today cut off tried to restart would not do anything and it is not the battery. Car will not crank no power to any of menu items like oil life.
Feb 18, 2018 at 10:55 AM
Good morning.
It could be a spark issue or fuel delivery issue.
How did you check the battery?
If you have a tachometer on the dash, does the needle move when the engine is cranking?
Feb 18, 2018 at 7:18 PM
