Car will not crank at all
250,000 MILES • 3.5L • 6 CYL • 2WD
DCONN
Just got this car in non running condition. Replaced starter, battery and ignition switch. When I go to turn it over all lights, fan all that works but wont crank a bit?! I tested starter outside car and it works great. I'm pretty much out of ideas. Not sure if it's a relay and i checked all fuses pretty sure.
Nov 28, 2019 at 7:47 AM
CJ MEDEVAC
  • 11,000 POSTS
Any clicks or noises when attempting a crank?
Have you tried to manually turn the engine over two revolutions with a wrench or ratchet to insure the engine ain't seized up? I'd do this with the battery disconnected!
Other than that, I got you two diagrams from "Prodemand".
I had to make two screenshots of each diagram in order to get them fully. I was sure to overlap them so nothing is lost.
Images 1 and 2 are for the automatic transmission starting system.
Images 3 and 4 are for the manual transmission starting system.
These should show everything involved.
The Medic
May 17, 2021 at 11:40 AM
DCONN
Okay, so that problem was fixed by finding out a fuse was not in proper location. now it cranks. thank you
