Car will not crank after removing driver side airbag
100,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
LEO ASHER
Okay, so we are turning the car listed above into a dirt track car. When we eliminated the driver side airbag now the car wont crank. Is there any way to bypass so the car will run?
Oct 7, 2019 at 10:45 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I've attached a picture of the airbag/restraint wiring diagram. I posted the diagram in 2 pictures to make larger by cutting in half.Hope this helps and thanks for using 2CarPros.
Danny-
Apr 15, 2021 at 11:47 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Removal of the airbag shouldn't cause it not to start. Was there anything other that was done? Also, is the starter engaging?
LEO ASHER
The car ran great before we removed airbag. Once we removed it there was nothing no click no nothing.
  • 110,248 POSTS
When you removed the airbag, did you have anything apart on the steering column? Was the battery disconnected when you did this? Also, do all other electrical components work? Also, check to make sure the ignition switch plug wasn't loosened, damaged, or disconnected. See picture 1.
LEO ASHER
Okay, thank you i will check this.
