Car will not crank
160,000 MILES • 2.4L • 5 CYL • 2WD • AUTOMATIC
.SPOOKYDWP
Turn key to start but nothing happens, except windshield wipers come on.
Oct 5, 2019 at 8:41 PM
Is the security light on?
Your engine control module has a disable feature that will get enabled when conditions are met.
Attached are the parameters. Let me know if the light is on. If not, we will need to check for voltage at the starter when the engine is not starting.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Let me know and we can go from there. Thanks
Oct 6, 2019 at 9:30 AM
JIS001
  • 3,412 POSTS
Hello and welcome to 2CarPros. Does your vehicle start and then shut down? Or does it not crank over at all? If it starts and shuts down then you have an immobilizer issue. If nothing happens do all the cluster lights come up? If they do then you could have a starter issue? Have the battery tested first and let us know if the battery is good.
Oct 11, 2019 at 5:23 PM
.SPOOKYDWP
New starter, alternator, battery, key fob battery, all fuses are good voltage everywhere. still nothing.
Oct 14, 2019 at 4:34 AM
Okay. So if it does nothing when the key is turned, we need to know if the security light is on and then when you say good voltage everywhere, does that mean you have proper voltage at the starter when cranking the engine? If you have proper voltage on both the B+ wire and signal wire then the starter should spin. If it is not, then you have a starter issue. However, since it is a new starter, I assume you don't have proper voltage at the starter.
Measure your voltage at the starter and tell me what you have at each wire while cranking the engine. Thanks
Oct 14, 2019 at 10:10 AM
.SPOOKYDWP
I'll have to buy another multi-meter and then I'll check voltage.
Oct 15, 2019 at 1:44 AM
.SPOOKYDWP
Yes the security light is on. it will turn off where the key fob and on with the key fob whether I'm inside or outside of the car.
Oct 15, 2019 at 1:45 AM
Just to clarify, the light blinks even if the key is in or out of the vehicle? Maybe get a video of you trying to start the vehicle so we can see what is happening. Just make sure the security light is in the video so we can see what it is doing. Thanks
Oct 15, 2019 at 9:55 AM
