If the sits on a flat surface for a day or two, the engine will not crank?
67,000 MILES • V6 • 2WD • AUTOMATIC
AL FOSSETT
After car sits on flat surface for a day or two it won’t crank. when pushed on a slight decline cranks up no problem.
Jul 29, 2022 at 9:15 AM
  • 55,845 POSTS
When you say crank do you mean run or the starter is not working when on a flat surface? If it is the latter, I would check the battery cables for corrosion. Also do the lights come on when on the flat ground? It could be a shorted battery. These guides can help us fix it. please go over them and get back to me.
and
and
Jul 30, 2022 at 4:05 AM
