Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
Concorde
Engine
Symptoms
Not Cranking Over
Engine will not crank
2002 CHRYSLER CONCORDE
165,000 MILES • 3.5L • 6 CYL • AUTOMATIC
JJ527
MEMBER
1 POST
I got my battery tested, my starter tested and my alternator also. but my car still won’t crank. does anyone know what the problem could be?
Sep 3, 2021 at 5:34 AM
Experienced Mechanic
Good evening,
I attached a wiring diagram of the starter circuit for you to view. There are a couple of fuses you need to test as well as a relay.
I attached the location of the relay. When you can, let me know and I can help guide you through the diagnostics.
Images (Click to enlarge)
Sep 3, 2021 at 11:36 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
