Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Riviera
Engine
Symptoms
Not Cranking Over
Car will not crank
1995 BUICK RIVIERA
40,000 MILES • 3.8L • 6 CYL
MIKL67
MEMBER
1 POST
Jump starting car, 40 below Celsius, Bendix kick in but no crank.
Jan 14, 2020 at 3:46 AM
Experienced Mechanic
When you say the Bendix kicks in but no crank, is the engine getting turned by the starter or do you just get one click?
If it is only one click, it sounds like the battery is weak. Have you tried to jump start it?
Here are a couple links you may find helpful:
https://www.2carpros.com/articles/how-to-jump-start-car-battery-using-jumper-cables
Jan 14, 2020 at 11:36 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
