Car will not accelerate
268,000 MILES • 4 CYL • 2WD • MANUAL
RYAN LIEBERMAN
Cars not accelerating like normal i replaced ERG valve and TPS sensor. The check engine light is not on since replacing ERG valve.
Apr 18, 2022 at 5:23 AM
  • 110,248 POSTS
Ryan,
Did this happen all at once? When you replaced the components, are you sure no vacuum lines or sensors were left disconnected?
Since there are no codes and it has a loss of power, the first thing I suspect is you may have a catalytic converter that is partially plugged. When you drive the vehicle, are there any odd sounds from the exhaust? Do you ever notice a rattling from the exhaust?
Take a look through this link and let me know your thoughts:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Apr 18, 2022 at 11:21 AM
