Car won't stay charged or start
180,000 MILES • RWD • MANUAL
PCKITTY8511
I replaced my car is a new battery and a new alternator and how to mechanic look at it also and I cannot figure out how come my car will not turn over and stay started when we jump it is they started barely if I don't stop the car could it be something to do with the fuses maybe
Dec 29, 2015 at 5:33 AM
PCKITTY8511
With a new battery, and had a mechanic look at it, stays started barely if I don't stop the car could it have something to do with my fuses
Dec 16, 2018 at 1:40 AM
HMAC300
  • 48,601 POSTS
try resetting security system then have battery tested including load test most places do for free. there is also a fusible link going to alternator that may have burnt out as well. see pic, however it may be a serial 2 data problem which a scanner needs to be hooked up. also it may be a draw on battery when car is off as well.
PCKITTY8511
Thank you for your help, I did take it to my mechanic who confirmed it was the fusible link that blew it was a 200 amp fuse which are not very easy to just pick up at Store even after that the Fixx of that is still has the problems so I will go ahead and take your second advice and have the code read off the computer and will update you
