Car wobbles at low speeds
133,000 MILES • V8 • AUTOMATIC
TONYSBABYGIRL
  • 67 POSTS
When my son bought this car the previous owner had two snow tires on front and two regular tires on the back. He gave us the other two regular and two snow tires. Everything felt fine until my son switched the front tires from the snow to the regular tires. Now at very low speeds the car wobbles. It feels like the wobbling is more in the back than the front.
I brought it to a mechanic, for a totally different reason, and asked him to balance the back tires (I was mistaken. I thought it was the back tires that my son changed over). The mechanic said the tires are bad (metal is sticking out) and that's why I'm getting the wobbling. It all made sense until my son pointed out that, like I said, it wasn't the back tires that got changed, it was the front.
So now nothing makes sense to me. If he just changed the front why does the wobbling feel like it's coming from the back? Could it just seem that way but it's really coming from the front? Also, at first I only felt the shaking in the car itself, not in the steering wheel, when going about 5-10 mph. Now at about 40 mph I'm feeling it more in the steering wheel. Also, I don't know if it's my imagination but the car feels a bit bouncier now.
May 24, 2019 at 6:12 PM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with your wheel bearing(s). Jack the vehicle up like you are going to change one of the tires. Make sure it's secure on jackstand(s). I have included a link below for how to properly do this if you are unfamiliar with how to do it.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Now, grab the tire you are checking and try to move the top towards the car and then away from the car. There should be no play at all. If there is then that wheels bearing is bad and needs to be replaced. Check all four tires and get back to us with what you find out. We can go from there.
Thanks,
Alex
2CarPros
May 24, 2019 at 6:59 PM
