Car with key symbol flashing without key
160,000 MILES
LELII
Hi I'm Ben and own a Toyota tarago 07 model.
I put key in and it stops flashing but car still wont start. Help please!!
My car was running perfect one day and the next day it wont start. I tried jump starting it,hitting the fuel tank underneath the car and it still wont run. It starts and then stops. The car with the key symbol flashes when the key is out of the ignition and once the key is in the ignition it stops flashing but still wont start.
An auto electrician told me it pops up as immobilisers fault to reprogram key again but it still wont start.
Can anybody help me please with this problem as ive payed hundreds of dollars and its still not fixed. Appreciate any help thanks
Oct 17, 2013 at 10:54 AM
MADMIKE1735
  • 951 POSTS
what did you pay for? diag? or getting the key reprogrammed to the vehicles computer??? usually only the dealer can tackle a task like that...
Oct 19, 2013 at 2:29 PM
LELII
I payed for a mobile mechanic to look at it. He said it was the key. He took it to his auto electrician who cut a new key and replaced the shell with a new one but still using the old chip. It still pops up immobiliser fault. I have not payed for a reprogramme yet
Oct 21, 2013 at 12:42 PM
LELII
Thank you mike for replying
Oct 21, 2013 at 12:56 PM
MADMIKE1735
  • 951 POSTS
sounds like the mobile tech was wrong.... unless the original key would not turn the ignition, there was no reason to replace the key.... if you have a fault for the imobilizer, then obviously there is a problem between the fob in your key, and the device that reads it.... in order to see which part failed is almost impossible without a dealer scan device.... they read data, and will justabout pinpoint what exactly failed.... the fob is just an inline resister.... they usually never fail.... im going to guess you have a wiring issue that is causing this.... i would recommend bringing to the dealer, as they will beable to pinpoint exactly, and solve this issue, fairly cheaply too i presume.
Oct 22, 2013 at 11:13 AM
LELII
Thank you mike. Your advice has helped me and my family save alot. I will go to the dealer and get the problem fixed. Appreciate your fast reply. Thank you thank you:)
Oct 22, 2013 at 3:17 PM
MADMIKE1735
  • 951 POSTS
i wish i could have walked you through the procedure, but again, this is online, and very difficult.... i wish you the best, and keep us in mind for future questions.
Oct 25, 2013 at 8:39 AM
VLANKY
Hi Ben, I have the exact problem with my car at present. Can you please advise how you fixed the problem. I still haven't taken the vehicle to a dealer yet however if you could help me out I would truly be grateful. Thank you
Nov 20, 2014 at 8:28 PM
