Lock symbol on the instrument panel?
134,555 MILES • 2.2L • 4 CYL • 2WD • MANUAL
AZDANNO04
  • 376 POSTS
I had the negative terminal disconnected from the battery when I was going to replace my shifter cables. Since I had the center consoles taken off. I just had to jack up the car to get the bolt loose off the bracket and gotten the fuse box disconnected and out the engine bay. I also cleaned up the grounds while that’s underneath the coolant tank. Since I had some ground issues. I wasn’t sure with the new cables that I got where the right ones. So, I put everything back together. Then when I tried started the car. It didn’t start and the car with a lock appeared. I googled and tried leaving the key on the on/run for ten minutes then off for five seconds and turning it on still nothing. Is there a fuse I can pull and reinsert to fix or bypass?
Feb 3, 2025 at 11:40 PM
  • 55,673 POSTS
You can't bypass the security system which is engaged. I would try a hard system reboot, please go over this guide:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
Please go over this guide and get back to us.
Feb 4, 2025 at 3:46 AM
