Car not charging
200,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
JBGAUSE01
My tachometer went out and the car wont charge. I put a new alternator and battery in and the car still wont charge. I suspect there is a short in the wiring but cannot find it.
Mar 21, 2019 at 2:22 AM
  • 110,248 POSTS
Welcome to 2CarPros.
The first thing I want you to check are fuses. I have attached a wiring schematic for the entire charging system. First, check fuses 8, 31, and the G which is a 75 amp fuse right from the battery. Locations are indicated on the schematic.
Here are a few links that may help when you are checking:
______________________
If all fuses are good, I need you to check the ground on the left side of the engine. It is a black wire which runs to the engine from the alternator. See schematic for G112.
If the ground shows good, then we need to confirm the alternator truly isn't working. It may be charging the battery but an electrical draw after the engine is off drains the battery.
Take a look through this link:
If voltage at the battery is around 14v with the engine running, then check for an electrical draw. See this link:
https://www.2carpros.com/articles/car-battery-dead-overnight
This is going to sound really elementary, but always start at the battery. Make sure the battery terminals are clean and tight. Also, check for evidence of corrosion or damage on main battery grounds.
Let me know what you find.
Mar 21, 2019 at 12:20 PM
