Car will turn over but will not start
110,000 MILES • 4 CYL • AUTOMATIC
KIMBERLY AVANT
Car revs up to 4rpm and shut off. Will not crank will turn over. Replaced throttle body, crank sensor and coil pack, still will not crank.
Jul 16, 2018 at 8:54 AM
  • 110,248 POSTS
If an engine fails to start when the starter engages and turns it, there are only a few things that can be wrong, no fuel or air to the engine, no spark from the ignition, ignition timing or broken timing belt, low compression/no compression. Take a look through these links which describes different causes for no start or hard start issues:
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Now, I need you to check for both spark and fuel to the engine. Here are the links which describe both:
I have attached a picture which contains the manufacturer's fuel pressure specifications.
Let me know if you have questions or need additional information.
Jul 17, 2018 at 1:26 PM
