Car will turn over but will not start
TEEFOX3
  • 2005 CHEVROLET AVEO
  • 1.6L
  • 4 CYL
  • 87,000 MILES
Coil and wire set are good. Spark plugs replaced. And they have a spark on ignition. Cam shaft position sensor tested good. Replaced crank shaft position sensor. Battery tested good and terminals are good. Fuel pump operates normally with good fuel pressure at the injector rail. Fuel in the tank. No engine fault codes on the computer.
Sunday, June 2nd, 2019 AT 7:00 PM
  • 109,885 POSTS
Welcome to 2CarPros.
If you have spark and fuel pressure, then either there is no injector pulse, low compression, or the timing belt broke or jumped.
First, here is a link that describes the most common causes of a crank no start:
Here is a link that explains how to check for an injector pulse:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Do me a favor, see if it will start for a couple seconds using starting fluid.
Sunday, June 2nd, 2019 AT 7:51 PM
