car will start once battery is jumped when the transmission is shifted into gear it shuts off?
200,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
LCUEVAS1203
car was being driven down highway when the heat cut off / potentially overheated and shuts off. was towed home, tried to do some simple things for repair. When car is started it will run pretty normally, maybe a little harder of an idle than normal but not too much and once put in gear the car turns off.
Jan 18, 2023 at 10:26 PM
  • 55,627 POSTS
How does the engine sound when cranking over? Can you please upload a short video of the engine cranking and running? I want to see if you lost compression due to the overheating. Also let's run the codes to see what comes up and service the throttle body.
https://www.2carpros.com/articles/stall-at-idle
and
Please go over these guides and report back.
Jan 20, 2023 at 2:06 AM
