Car will start and immediately shut off
19,750 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
BSAMP
I replaced the fuel filter and fuel pump. The car started and immediately shut of and would not start again. Help!
Dec 26, 2018 at 9:30 AM
  • 55,749 POSTS
When the engine stalls can you still hear the fuel pump in the back running. Also is the security light flashing?
This guide can help:
Dec 28, 2018 at 1:59 AM
BSAMP
You can hear the fuel pump but no red security light. I was told it could be a bad crankshaft sensor!
Dec 29, 2018 at 1:17 AM
  • 55,749 POSTS
Yep, that is what it sounds like but we should run the codes first. here is a guide:
If no codes are up which a bad crankshaft sensor will set no codes. here is a guide to help walk you through the job and the location of the sensor on your car in the diagrams below:
Dec 29, 2018 at 3:23 AM
BSAMP
Thanks!
Dec 29, 2018 at 8:00 AM
  • 55,749 POSTS
Dec 30, 2018 at 3:37 AM
