Car will not stay started
146,000 MILES • 3.6L • V6 • 2WD
VICTOR LAPOINT
I was having trouble with my car it would not start and shut off when I was driving. I replace the battery in my car it ran for about a day and a half and then it shut off again. so I took it to a friend of mine and he replaced the alternator in my car and when he went to start it it would not start. When he hooked his charger up to for about 45 minutes when he took the charger off it shut off again. any answers to that?
Jun 6, 2019 at 11:56 AM
  • 110,251 POSTS
Welcome to 2CarPros.
It sounds like either a dead/weak battery or a loose or corroded battery terminal. What I need you to do is first, load test the battery, second, check terminals, and last, confirm the alternator is working. I realize both the battery and alternator were replaced, so my first suspect is a loose or corroded connection. It sounds like a lot, but it's easy to do. Follow these links:
You will need a volt meter or multi meter to check the alt, but it is a very simple process. Here is a link that explains how to use a volt meter:
Do these things and let me know the results. And honestly, if the battery terminals are corrode, make sure to remove the terminals and clean both sides of the connection. Anytime there is an electrical issue like this, it's important to start where the power comes from.
Jun 7, 2019 at 4:28 PM
