car will not stay running
115,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
GREGORYBRENTON
Car will run for ten minutes or so then the lights on the dash start flashing mostly the temperature light and service engine light. then it shuts off and will not start back up for five minutes or so. then does it again. i have replaced the crank sensor, cam sensor, the ignition control module and map sensor. what is the next thing i am missing?
Mar 13, 2018 at 12:30 PM
HARRY P
  • 2,292 POSTS
Pull the codes when it does it. Being a 1992, it has OBD1, which you can pull the codes with a jumper wire in the connector. Here is a how-to guide for that:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Go ahead and do that when it does it, report the code(s) here. Also, make sure it is not overheating or something like that. If the cooling fan is working, then when the engine is off and key is off, feel the upper and lower radiator hoses. If there is a serious difference in temperatures, then coolant is not flowing like it should. Could be a clogged radiator, bad thermostat, etc. Some cars will shut down when the temperature reaches a certain point, but I am not sure whether or not this is one of those cars.
Mar 13, 2018 at 7:54 PM
GREGORYBRENTON
I hooked up a computer to the car and it gave me four codes the first was throttle sensor to high the second code was the throttle sensor to low the third was anti thief system failure but the car still cranks over but wont start now
Mar 15, 2018 at 4:01 AM
HARRY P
  • 2,292 POSTS
Do you remember the specific code numbers? As for the throttle sensor codes, you probably need a new one. That sensor has three wires in the connector. One is a positive lead. One is a ground. And the last is a signal wire (signal goes from sensor to the PCM). Probe two of them with a multi-meter and switch around until you get a +12 volt reading. Now you know which wire is which. You will leave the lead connected to the negative and take the other and connect it to the signal wire. Readings should be steady and go up and down with the throttle. If the readings are jumping all over the place, then you know that you need a new sensor.
Also, the anti-theft system can keep the car from starting. So if you have that code, I can look that up and see what to check.
Mar 15, 2018 at 11:44 AM
