car will not start,sounds like jump time
195,100 MILES • 2.2L • 4 CYL • 2WD • MANUAL
CARLAJEAN
car died while driving lost 2 quarts oil, sounds like it jumped time it just whines turning over ,will not start and low compression !! car did not use any at all..there is not any oil in water or water in oil !!! HELP
Jan 23, 2016 at 2:18 AM
HMAC300
  • 48,601 POSTS
this may be two fold it may have blown a head gasket and jumped time. if compression is equal all across like 90 psi or less then it's probably a chain then get it tested for a head gasket as well.
Jan 23, 2016 at 3:07 AM
CARLAJEAN
if it is the head gasket would it leak oil
Jan 23, 2016 at 3:12 AM
HMAC300
  • 48,601 POSTS
it could either leak oil to the coolant, into the cylinder or outside the engine. at base of cylinder head and block mating surface. it should be checked however first.
Jan 23, 2016 at 3:45 AM
