Car will not start after changing MAP sensor
194,000 MILES • 3.8L • V6 • AUTOMATIC
BOLO616
Code PO108 came up so I changed the MAP sensor and replaced the air filter. The car still will not start. Car listed above is a GT.
Mar 12, 2022 at 7:03 AM
  • 110,248 POSTS
Was the vehicle running prior to replacing the MAP? If you disconnect it, will the engine start? If you reinstall the old one, will it run?
Let me know. Also, take a look through this link and let me know if it helps at all:
https://www.2carpros.com/articles/car-not-running-advanced
I'll watch for your reply.
Mar 13, 2022 at 10:21 AM
