Car will not start
160,668 MILES • 4 CYL • 2WD • AUTOMATIC
NOT A MEKAINC
  • 7 POSTS
So I left my car idling for 10 minutes while I talked to my friend. when I got in my car the coolant light came on. I drove my car home the light went off, but now it won't start. could the coolant keep it from starting? it didn't look low but I'm not that great with cars.
Sep 19, 2021 at 7:36 PM
Good morning,
The coolant light usually indicates the level in the surge tank is low. I would fill the tank and pressure test the system to see if there are any leaks.
https://www.2carpros.com/articles/radiator-pressure-test
To run, you need fuel pressure, spark, and compression. I attached some guides for you to view to check these systems to determine the area of failure.
I attached the fuel pressure specs below. You can rent a tester at a parts store for the test.
Let us know if you have any other questions.
Sep 19, 2021 at 7:58 PM
NOT A MEKAINC
  • 7 POSTS
Thank you. I'll give it a shot.
Sep 19, 2021 at 10:02 PM
You are welcome.
Always glad to help.
Sep 19, 2021 at 10:04 PM
NOT A MEKAINC
  • 7 POSTS
Well, I really messed up. I was trying to replace the coolant temperature sensor and it snapped off so when trying to get the remaining out of the sensor it got tapped into the engine. so, I appreciate the help but I'm just going to send it on its way.
Sep 24, 2021 at 10:42 PM
Okay, we are here if you have any other questions.
Sep 25, 2021 at 5:26 AM
