I have not been able to start my car
318,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
QUIETSTORM_1980
I have not been able to start me car. I have changed sensors (crankshaft-2) and that is when it would not start. I figured it was the fuel pump so that was changed. Car still would not start. Next to change were the spark plugs, still no change in starting. It would crank but would not turn-over unless the spark plugs were taken out to see if they were burnt out. I am thinking it may be a the crankshaft sensor I purchased online. But that is just a guess.
Jan 9, 2020 at 12:42 AM
Just so I am clear, the issue stated when you put the crank sensor in that you bought online? If that is the case then yes. That is most likely the cause. I attached the part number from the OEM and I would suggest getting one of those and see what happens.
A crank sensor will prevent the start because it is needed to time the injectors and plugs.
Apr 25, 2021 at 6:28 AM
QUIETSTORM_1980
I purchased two of these. Are camshafts and crankshafts the same? What/ where fo I ho to purchase them?
The cam sensor and crank sensor are different but it appears they may be the same actual sensor or the same part number.
Here is a common parts website that should help. Screen shots below of all this info and of the website. One of the cam sensor and the other of the crank sensor.
https://www.rockauto.com/en/catalog/nissan,2006,altima,2.5l+l4,1432235,ignition,crankshaft+position+sensor,7196
QUIETSTORM_1980
I have a few questions because I feel you know what you're talking about and I feel that you won't steer me wrong but.. I brought my car to the dealership a few months back (November 2019). They gave me the OEM 23731-6N21A Crankshaft Position Sensor. They stated that I needed 2 of these. The price was outrageous ($240.00 tax included). My question is, does it matter the OEM or not?
Also, on the RockAuto website, does it matter which is used from the Ecomony and Standard Replacement?
Well thank you. I appreciate that.
I don't think they were deceiving you, I think they just didn't explain things very well. I have never seen a vehicle with 2 crank sensors. Which means they more than likely felt you needed two sensors and maybe they were the crank and cam sensor. Did they give you an estimate with this laid out?
As for what sensor, the OEM is the best because it was produced specifically for this vehicle from the original specifications made by the designers. All aftermarket sensors are called recastings. Meaning they took the original and made a copy of it which means they could get something wrong. Think of it like trying to copy a well known painting. It may look the same but it is not the original.
All this to say, just because it is not an OEM part, doesn't mean it is no good. I use aftermarket parts all the time and have good luck and not so good luck with them. Unfortunately, there is no guarantee with any of the parts you buy.
The way I look at it is I always evaluate cost vs, easy of replacement. If I have to take the engine apart to replace the sensor then I only want to do it once so I get the best quality part I can. However, if it is easy to replace, I will get the cheapest because if it fails I just swap it out.
As for Rock Auto, the standard part is considered an OEM replacement. The economy is normally the cheaper parts.
Hopefully I answered all your questions.
QUIETSTORM_1980
So as you can see, it wasn't very much! Anyway, I've ordered the cam and crank shaft from RockAuto and I should get it Tuesday. Cross your finger when it's installed, it works and I can go back to living again! Lol! Thanks for the info!
Hope your close to hear updates!
Yeah. That is parts and labor but still pretty pricey. Fingers are crossed. Let us know what happens. Thanks
