Car will not start
180,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
PHUONG TRAN
Car stall on highway will not restart, check no fall code, what wrong?
Nov 4, 2019 at 4:26 AM
  • 110,248 POSTS
Hi:
Does it restart after the engine cools? If so, most often it is related to the crankshaft position sensor.
Take a look through these links and let me know if they seem to mirror what you experience.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Nov 5, 2019 at 5:48 AM
PHUONG TRAN
I did replace a crankshaft sensor, however the car crank but still not start.
Nov 20, 2019 at 1:48 AM
  • 55,721 POSTS
When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? This guide can help:
Nov 20, 2019 at 1:49 AM
