Car will not start
155,000 MILES • TURBO • 4WD • AUTOMATIC
DARREN HUNTER
The car stopped when auto transmission temperature light came on. It remains on when trying to start engine. Please can you assist.
Dec 18, 2015 at 4:45 PM
HMAC300
  • 48,601 POSTS
check trans fluid then scan for codes.
Dec 18, 2015 at 10:55 PM
DARREN HUNTER
The fluid was low but now topped up is there a switch to take warning light off ? How can I get it to start ?
Dec 19, 2015 at 1:56 AM
DARREN HUNTER
Will it help turning the battery off & on again ?
Dec 19, 2015 at 2:00 AM
HMAC300
  • 48,601 POSTS
codes have to be removed by a scanner try resetting yoru security system if you have one then check fuses and relays like pgm or main pcm relay
Dec 19, 2015 at 4:16 AM
