Car will not start
1979 OLDSMOBILE DELTA 88
80,000 MILES • 0.5L • V8 • 2WD • AUTOMATIC
NORWICH
Car will not turn over the battery is good.
Feb 24, 2018 at 4:47 AM
  • CERTIFIED EXPERT
Good morning.
Does the starter work and crank the engine over?
You need spark, fuel and compression.
test for spark at the plugs.
Is there fuel in the carburetor?
Feb 24, 2018 at 5:50 AM
PATENTED_REPAIR_PRO
  • CERTIFIED EXPERT
  • 1,853 POSTS
I will assume since you are concerned about the battery that it is the starter that is not cranking over the engine. So, check if the purple wire to the starter solenoid has twelve volts when the key is turned to start.
Feb 24, 2018 at 6:40 AM
