test for spark at the plugs.
Is there fuel in the carburetor?
Feb 23, 2018 at 9:50 PM
PATENTED_REPAIR_PRO
✓Experienced Mechanic
I will assume since you are concerned about the battery that it is the starter that is not cranking over the engine. So, check if the purple wire to the starter solenoid has twelve volts when the key is turned to start.
