Car will not start
150,000 MILES • 2.7L • 4 CYL • 2WD • AUTOMATIC
LUNASUN
  • 5 POSTS
I replaced rotor and brakes. I flushed the radiator. I went to start it and nothing. It was running just fine before I did the work. What happen?? I am at a loss.
Mar 16, 2020 at 2:35 AM
  • 110,248 POSTS
I have a feeling something may have gotten wet when you flushed the cooling system. Do me a favor. I need you to check for ignition spark to the plugs. Here is a link that explains how it is done:
Let me know what you find. If there is no spark, I have a feeling the crankshaft position sensor got wet.
Now, if I misunderstood you and nothing happens when you crank it (no starter engagement) let me know. I am assuming that the starter is engaging but the engine fails to start. The brakes shouldn't have anything to do with this.
I will watch for your reply.
Mar 16, 2020 at 2:43 AM
LUNASUN
  • 5 POSTS
No there is nothing when I turn the key. It will not crank or even try to start. It is not that I did not. There was a communication problem.
Mar 16, 2020 at 2:44 AM
  • 110,248 POSTS
Does anything electrical work such as lights, horn, radio and so on? Is there a click or anything when you turn the key to the start position?
Mar 16, 2020 at 6:11 AM
LUNASUN
  • 5 POSTS
Lights, horn, radio. Every thing turns on and works. No click nothing when I turn the key.
Mar 16, 2020 at 6:19 AM
  • 110,248 POSTS
Okay. The starter may have been damaged from overheating or there could be an issue with the starter relay/fuse and so on.
First, I need you to check if there is power to the smaller wire on the starter when the key is in the start position. Here is a link to help:
Now, if there is power to the smaller wire, the battery is fully charged, and the larger wire on the starter (which has 12v all the time) is tight and clean and the battery terminals are tight and clean, replace the starter.
If not, check all fuses under the hood to see if anything is bad.
Mar 16, 2020 at 6:30 AM
LUNASUN
  • 5 POSTS
Okay, thank you I will. however, could it also be a security issue? The more I read about other cars issues I think this maybe. Is it possible to reset the security system?
Mar 16, 2020 at 6:33 AM
LUNASUN
  • 5 POSTS
Also the gear shift will not move.
Mar 16, 2020 at 6:35 AM
  • 110,248 POSTS
I think you have a blown fuse. The idea that it won't come out of park is indicating a power supply issue. Do me a favor (and this will sound odd) see if the brake lights work when you press the brakes.
Also, let me know if the gear indicator shows park.
Mar 16, 2020 at 7:08 AM
