Okay. The starter may have been damaged from overheating or there could be an issue with the starter relay/fuse and so on.
First, I need you to check if there is power to the smaller wire on the starter when the key is in the start position. Here is a link to help:
Now, if there is power to the smaller wire, the battery is fully charged, and the larger wire on the starter (which has 12v all the time) is tight and clean and the battery terminals are tight and clean, replace the starter.
If not, check all fuses under the hood to see if anything is bad.
Let me know what you find.
Mar 16, 2020 at 6:30 AM
