Car will not move in either direction
50,000 MILES • 1.8L • 5 CYL • 2WD • AUTOMATIC
RAHBARNETT
2012 VW Jetta SE...the car starts (no problem); goes into Reverse/Neutral/Drive/Sport (no problem). However, when in Reverse in will not move, only rise up a little. In Drive it will not move, just dip a little. If I place enough pressure on the gas pedal the car moves, almost like the hand-brake is engaged (which it is not).
It looks like the calipers are locked on the front rotors, but I really don't know.
Please Help!!!
Jul 6, 2015 at 12:02 AM
  • 31,937 POSTS
Jack the car up and see if you have a locked up wheel, start here.
Jul 11, 2015 at 10:39 PM
  • 55,808 POSTS
Hi Rahbarnett,
It sounds like you may have a broken axle, can you have a helper look at the axle while the car is in gear?
Best, Ken
Jul 12, 2015 at 4:38 AM
