1995 Volkswagen Jetta REVERSE
VWGTI962008
  • 1995 VOLKSWAGEN JETTA
  • 4 CYL
  • FWD
  • MANUAL
  • 235,000 MILES
Whats the esiest way to fix the reverse in a 95 jetta is a 5 speed
Tuesday, September 7th, 2010 AT 8:50 PM
VWTECH83
  • 39 POSTS
If you know what you are doing and are mechanically inclined you could simply remove transmission and rebuild it. But sometimes it is cheaper and easier to just replace the transmission assembly. Cost of parts and time to remove and reinstall transmission could be more expensive and more time consuming than just simply replacing the trans. Let me know if any other questions
Thursday, September 9th, 2010 AT 9:21 AM
VWGTI962008
Is it the clutch or transmission dont know witch one to replace
Monday, September 13th, 2010 AT 3:16 PM
VWTECH83
  • 39 POSTS
Does the clutch work fine when using 1st gear, 2nd gear, etc? If it does then clutch is probably fine. If reverse is the only gear not working then it is probably in the transmission. Especially if your clutch works fine while using other gears.
Monday, September 13th, 2010 AT 8:16 PM
