Car will not go into drive
150 MILES • 6 CYL • FWD • AUTOMATIC
TAY11
My car will not switch into drive. when I put it into drive it seems like it stays in neutral and the engine just revs. However, it switches into reverse fine with no problem. what could cause this problem?
Jan 19, 2017 at 4:49 AM
TAY11
Before this started happening the neutral light use to blink on and off.
Jan 19, 2017 at 5:13 AM
HMAC300
  • 48,601 POSTS
check transmission fluid if you can. if you can and it is dark brown or black probably time for a rebuild. you more than likely need this done and best bet is to have a transmission professional look at this.
Jan 19, 2017 at 5:37 AM
