car will not crank
93,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
ROY9319
Theft light flashes rapidly. Checked rx an tx wires from pats harness to PCM, continuity okay, and has voltage.Installed new transceiver module and had a locksmith reprogram keys. Still no crank. Then had dealer flash the PCM and it still will not crank. I should mention that after removing PCM harness and checking the wiring, the car started one time! Then no crank again. It looks like the key code is not being written to PCM memory. Cannot think of anything more I can do. Any advice would be appreciated. This Ford PATS system is ridiculous!
Jul 31, 2017 at 4:36 AM
STEVE W.
  • 15,418 POSTS
If removing the harness allowed it to start once I would check the connector and harness real close for a bad pin or damaged wire. It could simply be a loose pin.
Do not overlook the dash either. Ford loves to run all the signals through the instrument panel, a bad connection there could also cause this problem.
Jul 31, 2017 at 5:49 AM
ROY9319
Great idea Steve. I agree this could be the problem. I will give it a close look and get back with you.
Jul 31, 2017 at 6:19 AM
  • 55,766 POSTS
Please let us know what you find.
Cheers, Ken
Aug 2, 2017 at 6:44 AM
ROY9319
Checked all wires and pins. All ok.Found a Ford guy with the fancy Ford scanner. He did a PCM diagnostic and evidently the area where VIB writes to memory is malfunctioning. So, I suppose I will either have to get the PCM rebuilt or find a replacement that still works and get it reprogrammed to my VIN. What say you?
Aug 2, 2017 at 9:30 AM
STEVE W.
  • 15,418 POSTS
Shouldn't be difficult to find one that is OK and get it flashed. Not the first time an ECM refused to write properly.
Aug 2, 2017 at 4:39 PM
