Car will not move in gear
180,000 MILES • 3.8L • 6 CYL
ANGELA TUSING
Car will go into gear but will not move in reverse. in drive it will go a little bit then starts slipping.
Feb 11, 2018 at 3:25 PM
Good morning.
Check the fluid level to be sure it is correct. Low fluid level will cause this issue.
If that is correct, it could have a clogged filter in the transmission. When was the last time you changed the fluid and filter?
Is the check engine light on? if it is, do you know the code set?
Please let us know the results.
Feb 12, 2018 at 5:56 PM
ANGELA TUSING
Could it be as simple as a filter because my fluid is correct level.
Feb 13, 2018 at 12:31 PM
It is possible. Have the fluid and filter changed and see if it resolves your issue.
Feb 13, 2018 at 4:27 PM
