Car will crank, but will not start
150,879 MILES • 3.2L • V6 • 2WD • AUTOMATIC
FRENCHELL HARDWICK
  • 5 POSTS
Took my car to get aligned. The next morning it would not start. My husband, who is a mechanic, fooled with it. Got it started, turn it off. Same thing. Acted like it had a short. Changed crankshaft sensor and pig tail. Started twice, then would not start again. Any suggestions?
Apr 14, 2017 at 7:29 AM
HMAC300
  • 48,601 POSTS
scan for codes to see if any sensors are screwing up then try a security system reset they can cause this as well. I am assuming battery is clean and in good shape see link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Apr 15, 2017 at 12:13 AM
FRENCHELL HARDWICK
  • 5 POSTS
No codes. Not getting any fuel. Going to try and find camshaft sensor and check on fuel delivery. Will check security system.
Apr 15, 2017 at 12:21 AM
HMAC300
  • 48,601 POSTS
security may be the reason for no fuel so check security first.
Apr 15, 2017 at 4:13 AM
FRENCHELL HARDWICK
  • 5 POSTS
He is going to check security first as you suggested. Will let you know.
Apr 15, 2017 at 4:39 AM
FRENCHELL HARDWICK
  • 5 POSTS
Tried all of the security steps except pressing the alarm, which we do not have and still would not start.
Apr 15, 2017 at 8:06 AM
HMAC300
  • 48,601 POSTS
okay, spray choke cleaner into throttle if it starts then your fuel pump may have gone out if it starts then make a fist and pound bottom of gas tank it may free up pump for a little while.
Apr 15, 2017 at 8:46 AM
FRENCHELL HARDWICK
  • 5 POSTS
He sprayed something into the throttle it started. He is dropping the fuel tank today.
Apr 16, 2017 at 3:14 AM
  • 55,797 POSTS
Best, Ken
Apr 18, 2017 at 5:09 AM
YGRIEGA
  • 6 POSTS
I had that same problem with my 2001 rodeo sport. It would be fine, then I'd go to turn on and it would act as if out of gas. I'd have it towed to mechanic (I'd purchased extended warranty), he'd call me in a while and ask what was wrong-that it had no problem starting. I went through that at least 7 times then it stopped. One day around one year later it did it again. No way-I, went under hood; tapped on every lid and hose and it never happened again. I still have my isuzu-15 years old. Mine is only 4 cyl., manual transmission, zero extras (roll down your own window, no air conditioner, I wanted no more electronics than I had to have). Anyway-the reason I hit hoses and lids was I figured every ime I'd towed it, it had been jiggled around. Bubbles?
Jun 29, 2017 at 12:51 PM
  • 55,797 POSTS
This sounds like a classic fuel pump problem, Here is a guide that will show you what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Here is a diagram (below) of what it will be like on your car
Cheers, Ken
Jun 30, 2017 at 3:39 AM
YGRIEGA
  • 6 POSTS
Hi Ken. I haven't had a problem with my car since I hit the tops of everything under the hood. Bfore that they had replaced everything pertaining to the fuel lines etc. I DO have a major problem now. My car had a code of cam position sensor and won't pass smog. I don't know how to take the lid that's covering the sensor. I have the picture of where it is. Can you tell me how to take the black cover off the thing. Sorry bout the technical words. Haha Thank you, Lori
Jul 12, 2017 at 8:48 AM
  • 55,797 POSTS
Hi Lori,
Can you please start a new question?
Best, Ken
Jul 12, 2017 at 8:54 AM
  • 55,797 POSTS
Please post your question here
Cheers, Ken
Jul 13, 2017 at 4:35 AM
