Car will crank but will not turn over
210,000 MILES • 4 CYL • AWD • AUTOMATIC
PATRICE PORTER
I can rock the car, it cranks. Push the car while in Neutral and it will crank.
Mar 1, 2016 at 5:35 AM
CATAFINA
  • 167 POSTS
If it can crank on P/N -your best bet is to check fuel pressure to see if its within specs and also look for spark and then check engine compression
Mar 1, 2016 at 6:08 AM
HMAC300
  • 48,601 POSTS
Try resetting your security system if no manual look online for your car to reset it.
Mar 1, 2016 at 7:22 AM
PATRICE PORTER
The car will crank, but will not catch or turn over. It may crank and turnover if the car is sharpened or maybe push while in Neutral position,the car only runs when on the diagnostic machine?
Mar 2, 2016 at 12:52 AM
HMAC300
  • 48,601 POSTS
try resetting your security system if no manual look online for your car.
Mar 2, 2016 at 3:59 AM
