Car was running fine yesterday, but when I tried to start it today it just cranks over and will not fire. Initially suspected it was the typical problem for this model of oil getting to the distributor, I've changed the distributor three times since new but normally I get a warning period of the car running rough but not this time.
I've checked and confirmed I'm getting good spark from the coil and to all 4 spark plugs, (cleaned and set spark plugs gaps and cleaned battery terminals while I was at it) went to check the fuel at the filter but noticed that when I pull on the throttle cables with the ignition on I get a buzzing sound from below the throttle levers, not sure if this is normal or not?
Last weekend I changed the leaking water pump (removed alternator and air conditioner etc.) and replaced the serpentine belts while I was at it. Car has done 15-20 trips since then and was running fine.
Any thoughts on the buzzing sound, I'll go out and check the fuel flow while I'm waiting.
Kind regards
Jim
Kind regards
Jim
Apr 12, 2014 at 10:41 AM
