Car will crank but no gas or spark
TJDERICKSON
  • 2003 HYUNDAI ELANTRA
  • 2.0L
  • 4 CYL
  • FWD
  • 187,000 MILES
Running fine and turned heat on and car died. The only thing it will do is crank over the fuel pump is not kicking on and im not getting any spark at the plugs. Car will not let a hang help computer read any codes off of it.
What does ECM computer do? Tried replacing cam and crank shaft sensors with no luck, need to know what to do as I cannot afford to take it to a mechanic.
Wednesday, December 24th, 2014 AT 9:48 PM
WRENCHTECH
  • 20,761 POSTS
Someone with some electrical knowledge and the ability to read a wiring diagram will have to troubleshoot the circuits to find the issue but i suspect something to do with the main relay which, in turn powers the fuel pump relay and most everything else.
I would start out by testing ALL the fuses with a test light at both end of the fuse with the key on.
https://www.2carpros.com/images/external/110495016.gif
Thursday, December 25th, 2014 AT 5:30 AM
